JBL Charge 3 Front Cover Replacement
  1. JBL Charge 3 Front Cover Replacement, Front Cover: step 1, image 1 of 3 JBL Charge 3 Front Cover Replacement, Front Cover: step 1, image 2 of 3 JBL Charge 3 Front Cover Replacement, Front Cover: step 1, image 3 of 3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Front Cover Replacement: step 2, image 1 of 1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
Aidan Hays
3,842 Reputation
2 Guides authored
Cal Poly, Team S13-G1, White Fall 2018 Member of Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
3 Members
26 Guides authored
Past 24 Hours: 11
Past 7 Days: 30
Past 30 Days: 107
All Time: 9,043
