JBL Charge 2 Teardown
Video Overview
  1. JBL Charge 2 Teardown, Protection Grids: step 1, image 1 of 2 JBL Charge 2 Teardown, Protection Grids: step 1, image 2 of 2
    • Use a plastic spatula or credit card to open the grids
    • You should not have to exert too much force on the grids. There is a little bit of glue on it.
  2. JBL Charge 2 Teardown, Screw!: step 2, image 1 of 2 JBL Charge 2 Teardown, Screw!: step 2, image 2 of 2
    • Remove the first 4 screws
    • Blow up the round of plastic then take care of the remaining 4 screws.
  3. JBL Charge 2 Teardown, We're in!: step 3, image 1 of 2 JBL Charge 2 Teardown, We're in!: step 3, image 2 of 2
    • Now you can access the motherboard.
    • To disconnect the battery: disconnect the microphone first, it will make things easier.
  4. JBL Charge 2 Teardown, Drums: step 4, image 1 of 2 JBL Charge 2 Teardown, Drums: step 4, image 2 of 2
    • Unscrew the two screws of the white cover
    • Get out of his notch, and here's the battery!
    Nice tutorial on how to dismantle the device, but what if I want to separate out the power bank part of this device and dump the rest due to worn out speakers. Is it possible to do that? If not, will it still work as a power bank if I simply the wires to the speakers and remove them. I’d rather remove the amplifier as well so that unnecessary power consumption is reduced.
    David Moody - Reply
10 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Alexandre Isaac
2,863 Reputation
8 Guides authored
The Repair Academy Member of The Repair Academy
Business
1 Member
20 Guides authored
13 Comments
About to try this, will give feedback
Rick Purchase - Reply
This is the charge2 + not the charge2
The Daniel - Reply
there aren,t any screws in the cap
Norman Ingham - Reply
I have the same problem. I think this is a TL model, but I have not been able to find any information on how to correctly remove the end caps. I don’t want to scratch or break anything trying to pop the end caps off.
Bobcov -
Thanks so much! I had a broken bit of plastic inside the tube after I left my speaker in my checked luggage and it got smashed around. I followed the instructions and managed to get it out, the speaker is purring again without the annoying ass rattle!! You're a legend my friend. TY
itgotfixed - Reply
You are welcome !
Alexandre Isaac -
Hello, I have a problem
I lost the speaker screws
can you tell me what type of screws I have to buy?
thank you in advance
bilal mesrour - Reply
Ce tuto ne concerne PAS le charge 2, mais bien le charge 2+
Le principe d’ouverture est bien différent !
jf.dedecker - Reply
So easy steps to follow. Thank you so much. The guide is really helpful.
It came handy when my boss complained about a fault, so I tried figuring it out, then I googled steps to dismantle, and pop! The video showed up. Really helpful. Thanks
omo4rmzion - Reply
This tutorial really helped :)
JITHIN ROY - Reply
Bonjour à tous, je constate que sur ce tuto on a des personnes qui gèrent donc bcp d'amitié
et de remerciement à tous vous êtes tjrs en mode cool et ça fait vraiment merci et n'hésitez pas à me demander un service
je serai fier de vous rendre service et encore merci Thameur
Thameur TRABELSI - Reply
comme vous l'avez sans doute compris "bcp plaisir"
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 136
All Time: 50,433
