JBL Charge 2+ Speaker Replacement
    1. JBL Charge 2+ Speaker Replacement, Uncovering the Speakers: step 1, image 1 of 3 JBL Charge 2+ Speaker Replacement, Uncovering the Speakers: step 1, image 2 of 3 JBL Charge 2+ Speaker Replacement, Uncovering the Speakers: step 1, image 3 of 3
      • Remove the metal grill: starting from bottom-left corner, use a guitar pick or spudger to lift the metal grill.
      • *Pro-tip* if it feels like it's not moving, just be patient and do not try to use more force: apply a gentle continuous pressure and it will slowly starting coming off. Be patient.
      • Unscrew the four screws that hold each speaker in place (8 total).
      Ask FixBot
    2. JBL Charge 2+ Speaker Replacement, remove: step 2, image 1 of 3 JBL Charge 2+ Speaker Replacement, remove: step 2, image 2 of 3 JBL Charge 2+ Speaker Replacement, remove: step 2, image 3 of 3
      • Slide each of the quick cables from the speaker off.
      Ask FixBot
      • Replace the speakers : simple reinstall in reverse order.
      • To reinstall the metal grille: gently and firmly line it up and press into place. If needed, use the spudging tool to guide the last corners into place.
      Ask FixBot
12 other people completed this guide.
John Reynolds
3,354 Reputation
4 Guides authored
UMass Dartmouth, Team 4-1, Catania Fall 2015 Member of UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 Members
60 Guides authored
11 Guide Comments
How did you remove the IRON NET ?
Olivier - Reply Share
http://bit.ly/1VlVWXH - First step in this guide. Hope this helps :)
Tapiwa - Reply Share
hello
where can i find this speaker replacement?
amati - Reply Share
I believe I blew my speakers, where/how can I purchase replacement speakers?
Francisco Garcia - Reply Share
Where to buy these speakers online?
aurimasslepikas - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 114
All Time: 30,490
