JBL Flip 4 Shell Replacement
    1. JBL Flip 4 Shell Replacement, Shell: step 1, image 1 of 3 JBL Flip 4 Shell Replacement, Shell: step 1, image 2 of 3 JBL Flip 4 Shell Replacement, Shell: step 1, image 3 of 3
      • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
      • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
      • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
      • Watch out not to damage the clips on the buttons' side, pry open with caution.
      • Pull the cover off with your thumbs.
      Ask FixBot
    2. JBL Flip 4 Shell Replacement: step 2, image 1 of 3 JBL Flip 4 Shell Replacement: step 2, image 2 of 3 JBL Flip 4 Shell Replacement: step 2, image 3 of 3
      • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
      • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
      • Pry away one end of the rubber spine with your thumbs and it should come off.
      • Prying off the spine may take some persuading.
      • The speakers are strong magnets. Keep it away from other sensitive electronics.
      Ask FixBot
10 other people completed this guide.
Philip Pang
1,470 Reputation
4 Guides authored
Cal Poly, Team S4-G3, White Fall 2018 Member of Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
4 Members
60 Guides authored
3 Guide Comments
教程不难, 难的是哪里可以买到配件。
Toki - Reply Share
Buenas tarde busco remplazo de carcasa frontal del jbl flit 4
william marin lopez - Reply Share
@williammar67632 si encontro la pieza disculpe
Gerardo Parra - Reply Share
Past 24 Hours: 6
Past 7 Days: 64
Past 30 Days: 255
All Time: 19,015
