Isuzu Trooper Check Engine Light Trouble Code Reading
Views: 1.4K
View statistics:
Past 24 Hours:
8
Past 7 Days:
38
Past 30 Days:
150
All Time:
1,384
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
How to check what trouble code a check engine light means on a first generation Isuzu Trooper (1981–1991).
    1. Isuzu Trooper Check Engine Light Trouble Code Reading, Diagnostic trouble code info: step 1, image 1 of 1
      • If a problem develops in a monitored system with the engine running, the Check Engine light (CEL) will come ON and a trouble code will be stored in ECM memory.
      • As long as a problem is present, the light will remain on while the engine is running. If the problem is intermittent, the light will go out but a trouble code will be stored in ECM memory.
      • As a bulb check, the Check Engine light will come on with the ignition switched on and the engine not running. If no codes are present, the light will go out upon starting the engine. If the light remains on, the system has detected a fault.
      Ask FixBot
    2. Isuzu Trooper Check Engine Light Trouble Code Reading, How to access trouble codes: step 2, image 1 of 1
      • To access trouble codes, a test lead (white wire) and ground lead (black wire) are branched from the wiring harness under the center console near the ECM.
      • With the ignition "ON" connect these two leads together.
      • The "Check Engine" light will begin to flash code 12. Code 12 consists of one flash, a short pause, then two flashes. After a longer pause, code 12 will repeat two more times.
      • This check indicates that the on-board diagnostic system is functioning. If no other codes are present, the cycle will repeat until the ignition is switched "OFF."
      Ask FixBot
    3. Isuzu Trooper Check Engine Light Trouble Code Reading, How to read trouble codes: step 3, image 1 of 1
      • If trouble codes are stored in memory, the lowest number code will flash three times followed by the next higher code number until all stored codes have been displayed.
      • The codes will then repeat in the same order until the test lead is disconnected. Code 14, for example, indicates a problem in the coolant sensor circuit.
      • To clear a code from memory, disconnect the battery.
      Ask FixBot
      • CODE 12: Indicates that on-board diagnostics are functioning when diagnostic leads are connected and ignition is "ON" (engine not running). Code not stored in memory.
      • CODE 13: Oxygen sensor defective or open circuit.
      • CODE 14: Shorted coolant sensor circuit.
      • CODE 15: Open coolant sensor circuit.
      • CODE 21: Both idle and wide open throttle ON simultaneously in throttle valve switch.
      • CODE 22: Open or shorted starter signal circuit.
      • CODE 23: Shorted power transistor output terminal.
      • CODE 25: Open or shorted circuit for pressure regulator VSV.
      Ask FixBot
      • CODE 26: Open or shorted circuit for canister VSV.
      • CODE 27: Open in ECM driver transistor for canister VSV.
      • CODE 32: EGR gas temperature sensor malfunction.
      • CODE 33: Open or shorted circuit in fuel injector harness, dropping resistor or inside ECM.
      • CODE 34: EGR gas temperature sensor or wiring faulty.
      • CODE 35: Ignition power transistor harness open circuit.
      • CODE 41: Crank angle sensor open circuit or faulty signal.
      • CODE 43: Throttle valve switch idle contact continuously ON.
      Ask FixBot
      • CODE 44: Lean signal from oxygen sensor.
      • CODE 45: Rich signal from oxygen sensor.
      • CODE 51: Abnormal ROM in ECM micro computer.
      • CODE 52: Abnormal RAM in ECM micro computer.
      • CODE 53: Open in ECM driver transistor for pressure regulator VSV.
      • CODE 54: Defective ignition power transistor or grounding system.
      • CODE 61: Shorted or broken air flow sensor hot wire.
      • CODE 62: Broken air flow sensor cold wire.
      Ask FixBot
      • CODE 63: Open or shorted wiring or defective vehicle speed sensor.
      • CODE 64: Open in ECM driver transistor for fuel injectors.
      • CODE 65: Wide open throttle contact in throttle valve switch continually ON.
      Ask FixBot
Finish Line
Carsten Frauenheim
173,391 Reputation
442 Guides authored
1 Guide Comment
Gracias por la información es muy valiosa para realizar una reparación a mi vehículo
Félix - Reply Share
Past 24 Hours: 8
Past 7 Days: 38
Past 30 Days: 150
All Time: 1,384
