Ion Air Pro Power Button Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
67
All Time:
1,006
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 9 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Is your camera not turning on or turning off? Consider using this guide to replace the power button of your device.
Tools
    1. Ion Air Pro Power Button Replacement, Power Button: step 1, image 1 of 1
      • Remove the 6 screws that secure the lens cover bezel with a #00 Phillips screwdriver.
      Ask FixBot
    2. Ion Air Pro Power Button Replacement: step 2, image 1 of 1
      • Slide off the black aluminum casing.
      Ask FixBot
    3. Ion Air Pro Power Button Replacement: step 3, image 1 of 1
      • Unscrew the top screw that is by the power button using a #00 Phillips screwdriver.
      • A spring is being held down by the screw. be sure to hold it down.
      Ask FixBot
    4. Ion Air Pro Power Button Replacement: step 4, image 1 of 1
      • Lift off the plastic part holding the power button in place.
      Ask FixBot
    5. Ion Air Pro Power Button Replacement: step 5, image 1 of 1
      • Remove the power button from the device.
      Ask FixBot
Christopher Brandl
673 Reputation
5 Guides authored
UW Stout, Team S6-G2, Ogden Fall 2018 Member of UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 67
All Time: 1,006
