Installing Inter-tel IP 8660 Rear Cover
  1. Installing Inter-tel IP 8660 Rear Cover, Rear Cover: step 1, image 1 of 1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Installing Inter-tel IP 8660 Rear Cover: step 2, image 1 of 3 Installing Inter-tel IP 8660 Rear Cover: step 2, image 2 of 3 Installing Inter-tel IP 8660 Rear Cover: step 2, image 3 of 3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Installing Inter-tel IP 8660 Rear Cover: step 3, image 1 of 1
    • Lift up the back cover and set it aside.
Mariano Bautista
16 Reputation
2 Guides authored
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 543
