Installing Inter-tel IP 8660 Motherboard
  1. Installing Inter-tel IP 8660 Motherboard, Rear Cover: step 1, image 1 of 1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Installing Inter-tel IP 8660 Motherboard: step 2, image 1 of 3 Installing Inter-tel IP 8660 Motherboard: step 2, image 2 of 3 Installing Inter-tel IP 8660 Motherboard: step 2, image 3 of 3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Installing Inter-tel IP 8660 Motherboard: step 3, image 1 of 1
    • Lift up the back cover and set it aside.
  4. Installing Inter-tel IP 8660 Motherboard, Internal speaker: step 4, image 1 of 1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Installing Inter-tel IP 8660 Motherboard: step 5, image 1 of 1
    • Lift up the speaker.
  6. Installing Inter-tel IP 8660 Motherboard, LCD Screen: step 6, image 1 of 3 Installing Inter-tel IP 8660 Motherboard, LCD Screen: step 6, image 2 of 3 Installing Inter-tel IP 8660 Motherboard, LCD Screen: step 6, image 3 of 3
    • Lift up the motherboard out of its housing in the front cover of the phone.
    • Set the front cover and button pads aside.
  7. Installing Inter-tel IP 8660 Motherboard: step 7, image 1 of 3 Installing Inter-tel IP 8660 Motherboard: step 7, image 2 of 3 Installing Inter-tel IP 8660 Motherboard: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, pinch the highlighted connective clips together and depress. Start with the clips in the middle of the motherboard first.
    • Note: There are four clips, one at each corner of the LCD screen.
  8. Installing Inter-tel IP 8660 Motherboard: step 8, image 1 of 1
    • Flip the motherboard over so that the LCD screen is facing upward.
  9. Installing Inter-tel IP 8660 Motherboard: step 9, image 1 of 2 Installing Inter-tel IP 8660 Motherboard: step 9, image 2 of 2
    • Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
    • This is done using the spudger to lift one side out of its housing.
    • Reposition the spudger to the other side of the black clip and push it flush with the other end.
    • Note: The black clip pushes out of the housing and does not come completely loose.
  10. Installing Inter-tel IP 8660 Motherboard: step 10, image 1 of 3 Installing Inter-tel IP 8660 Motherboard: step 10, image 2 of 3 Installing Inter-tel IP 8660 Motherboard: step 10, image 3 of 3
    • Pull gently on the ribbon cable so that it comes loose from the black clip.
Mariano Bautista
16 Reputation
2 Guides authored
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
14 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,121
