Inter-tel IP 8660 Internal speaker Replacement
  1. Inter-tel IP 8660 Internal speaker Replacement, Rear Cover: step 1, image 1 of 1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Internal speaker Replacement: step 2, image 1 of 3 Inter-tel IP 8660 Internal speaker Replacement: step 2, image 2 of 3 Inter-tel IP 8660 Internal speaker Replacement: step 2, image 3 of 3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Internal speaker Replacement: step 3, image 1 of 1
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Internal speaker Replacement, Internal speaker: step 4, image 1 of 1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Internal speaker Replacement: step 5, image 1 of 1
    • Lift up the speaker.
Megan Buck
15 Reputation
1 Guide authored
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 789
