Inter-tel IP 8660 Button Pad Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
88
All Time:
1,290
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide details the steps to take off the button pad of your Inter-tel IP 8660.
Tools
    1. Inter-tel IP 8660 Button Pad Replacement, Rear Cover: step 1, image 1 of 1
      • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
      Ask FixBot
    2. Inter-tel IP 8660 Button Pad Replacement: step 2, image 1 of 3 Inter-tel IP 8660 Button Pad Replacement: step 2, image 2 of 3 Inter-tel IP 8660 Button Pad Replacement: step 2, image 3 of 3
      • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
      • 8 mm long
      • 11 mm long
      Ask FixBot
    3. Inter-tel IP 8660 Button Pad Replacement: step 3, image 1 of 1
      • Lift up the back cover and set it aside.
      Ask FixBot
    1. Inter-tel IP 8660 Button Pad Replacement, Internal speaker: step 4, image 1 of 1
      • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
      Ask FixBot
    2. Inter-tel IP 8660 Button Pad Replacement: step 5, image 1 of 1
      • Lift up the speaker.
      Ask FixBot
    1. Inter-tel IP 8660 Button Pad Replacement, Button Pad: step 6, image 1 of 1
      • Lift up the motherboard and set aside
      Ask FixBot
    2. Inter-tel IP 8660 Button Pad Replacement: step 7, image 1 of 1
      • Peel off all rubber button covers.
      Ask FixBot
    3. Inter-tel IP 8660 Button Pad Replacement: step 8, image 1 of 1
      • Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
      Ask FixBot
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 88
All Time: 1,290
