Shop the Holiday Gift Guide
Instrument Cluster - Removal
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
44
All Time:
44
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Here I'll show you how to remove the instrument cluster.
    1. Instrument Cluster - Removal, Instrument Cluster: step 1, image 1 of 2 Instrument Cluster - Removal, Instrument Cluster: step 1, image 2 of 2
      • Carefully pry out the climate control bezel with the plastic wedge (be careful, the cables to the climate control panel are very short).
      • Disconnect the connector from the climate control panel.
      Ask FixBot
    2. Instrument Cluster - Removal: step 2, image 1 of 1
      • Next, remove the passenger side trim strip. To do this, remove the screw circled in red and then carefully pry out the trim strip.
      Ask FixBot
    3. Instrument Cluster - Removal: step 3, image 1 of 1
      • Now remove the trim strip between the climate control panel and the steering wheel. Again, remove the screw circled in red and carefully pry out the strip.
      Ask FixBot
    4. Instrument Cluster - Removal: step 4, image 1 of 1
      • The trim strip with the mirror adjustment and headlight leveling controls is only clipped in. Carefully pry it out and, if your car has these features, disconnect the 2 cables.
      Ask FixBot
    5. Instrument Cluster - Removal: step 5, image 1 of 2 Instrument Cluster - Removal: step 5, image 2 of 2
      • Remove the 3 screws marked in red (for the third one, remove the fuse box cover first).
      Ask FixBot
    6. Instrument Cluster - Removal: step 6, image 1 of 3 Instrument Cluster - Removal: step 6, image 2 of 3 Instrument Cluster - Removal: step 6, image 3 of 3
      • Unscrew the 2 screws marked in red.
      Ask FixBot
    7. Instrument Cluster - Removal: step 7, image 1 of 3 Instrument Cluster - Removal: step 7, image 2 of 3 Instrument Cluster - Removal: step 7, image 3 of 3
      • Remove the 4 screws. The exact position of 2 of them is shown in the next step.
      Ask FixBot
    8. Instrument Cluster - Removal: step 8, image 1 of 2 Instrument Cluster - Removal: step 8, image 2 of 2
      • Remove the screws.
      • Now pull out the bezel; along the top it is only clipped in.
      • If equipped, unplug the trip computer.
      Ask FixBot
    9. Instrument Cluster - Removal: step 9, image 1 of 3 Instrument Cluster - Removal: step 9, image 2 of 3 Instrument Cluster - Removal: step 9, image 3 of 3
      • Loosen the 4 screws and you can pull out the instrument cluster.
      Ask FixBot
    10. Instrument Cluster - Removal: step 10, image 1 of 1
      • When reassembling, note that the screws with the large head (left) are for steps 5 and 6.
      Ask FixBot
Special thanks to these translators:
de en
100%
Migi is helping us fix the world! Want to contribute?
Start translating ›
Migi
750 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 44
All Time: 44
