Shop the Holiday Gift Guide
Instant Pot 60 EPC Pressure Sensor Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
50
Past 30 Days:
156
All Time:
1,652
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The following guide is for replacing the pressure sensor on an Instant Pot 60 EPC. Consider following this guide if you have issues with your pressure readings or recieve the errors C6, C6L, or C6H and cleaning the contacts was unhelpful.
Parts
Tools
    1. Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: step 1, image 1 of 3 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: step 1, image 2 of 3 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: step 1, image 3 of 3
      • Ensure the device is unplugged and cool before beginning.
      • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
      • Remove the single Torx screw.
      Ask FixBot
    2. Instant Pot 60 EPC Pressure Sensor Replacement: step 2, image 1 of 2 Instant Pot 60 EPC Pressure Sensor Replacement: step 2, image 2 of 2
      • Turn the bottom face counterclockwise and remove it.
      Ask FixBot
    3. Instant Pot 60 EPC Pressure Sensor Replacement: step 3, image 1 of 3 Instant Pot 60 EPC Pressure Sensor Replacement: step 3, image 2 of 3 Instant Pot 60 EPC Pressure Sensor Replacement: step 3, image 3 of 3
      • In order to reach the pressure sensor you'll need to remove the secondary frame.
      • Remove the three Phillips screws securing the frame.
      • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
      • Locate the sensor. It has been highlighted in the final image.
      Ask FixBot
    4. Instant Pot 60 EPC Pressure Sensor Replacement: step 4, image 1 of 2 Instant Pot 60 EPC Pressure Sensor Replacement: step 4, image 2 of 2
      • To remove the sensor, unscrew the main screw between the sensor and slide out.
      Ask FixBot
    5. Instant Pot 60 EPC Pressure Sensor Replacement: step 5, image 1 of 3 Instant Pot 60 EPC Pressure Sensor Replacement: step 5, image 2 of 3 Instant Pot 60 EPC Pressure Sensor Replacement: step 5, image 3 of 3
      • To remove the leads connecting the sensor to the motherboard you will need to unclip them.
      • In order to do so, slide the blue covering up to expose the small hole in the lead.
      • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not avaliable then a paperclip or earring should suffice.
      Ask FixBot
    6. Instant Pot 60 EPC Pressure Sensor Replacement: step 6, image 1 of 2 Instant Pot 60 EPC Pressure Sensor Replacement: step 6, image 2 of 2
      • There will be a secondary lead that is black connecting the sensor the the motherboard.
      • In order to remove that lead just squeeze and pull up.
      Ask FixBot
    7. Instant Pot 60 EPC Pressure Sensor Replacement: step 7, image 1 of 1
      • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
      Ask FixBot
4 other people completed this guide.
Author
with
Bela Hernandez
1,016 Reputation
5 Guides authored
2 Guide Comments
My pro plus comes with only one sensor. Where can I find it's replacement?
Dr. Khalid S - Reply Share
How does the pressure sensor work?
tjmurf - Reply Share
Past 24 Hours: 5
Past 7 Days: 50
Past 30 Days: 156
All Time: 1,652
