Dell Inspiron 530 CD/DVD Drive Replacement
  1. Dell Inspiron 530 CD/DVD Drive Replacement, Side Panel: step 1, image 1 of 1
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Dell Inspiron 530 CD/DVD Drive Replacement: step 2, image 1 of 1
    • Slide the side panel towards the back and remove.
  3. Dell Inspiron 530 CD/DVD Drive Replacement, CD/DVD Drive: step 3, image 1 of 1
    • Locate the CD/DVD drive in the upper-front corner of the case.
  4. Dell Inspiron 530 CD/DVD Drive Replacement: step 4, image 1 of 1
    • Locate and remove the two cables attached to the CD/DVD drive.
  5. Dell Inspiron 530 CD/DVD Drive Replacement: step 5, image 1 of 1
    • Locate and remove the two Phillips #0 7.8 mm screws.
  6. Dell Inspiron 530 CD/DVD Drive Replacement: step 6, image 1 of 1
    • Locate the three plastic tabs connecting the computer's faceplate to the case.
    • Gently lift the three tabs to pull off the faceplate.
  7. Dell Inspiron 530 CD/DVD Drive Replacement: step 7, image 1 of 1
    • Pull the faceplate forward and out.
  8. Dell Inspiron 530 CD/DVD Drive Replacement: step 8, image 1 of 1
    • Completely remove the faceplate.
    • Remove the CD/DVD drive by pulling it forward towards the front.
17 other people completed this guide.
Doug Howe
2,161 Reputation
2 Guides authored
Cal Poly, Team 6-8, Regan Fall 2011 Member of Cal Poly, Team 6-8, Regan Fall 2011
CPSU-REGAN-F11S6G8
4 Members
18 Guides authored
One Comment
add the problems may happen and ther solution
mersen getu - Reply
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 45
All Time: 17,449
