iPod Touch 5th Generation Rear-Facing Camera Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: step 1, image 1 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: step 1, image 2 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: step 1, image 3 of 3
    • Insert the flat end of a spudger between the rear-facing camera and its frame.
    • Gently twist the spudger to free the camera.
    • Lift the rear-facing camera up out of its socket, and remove it from the iPod Touch.
  2. iPod Touch 5th Generation Rear-Facing Camera Replacement: step 2, image 1 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: step 2, image 2 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: step 2, image 3 of 3
    • Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
    • Run the spudger along the full length of the tape to disconnect it from the rear case.
  3. iPod Touch 5th Generation Rear-Facing Camera Replacement: step 3, image 1 of 2 iPod Touch 5th Generation Rear-Facing Camera Replacement: step 3, image 2 of 2
    • Peel and remove the foam tape from the rear case of the iPod.
  4. iPod Touch 5th Generation Rear-Facing Camera Replacement: step 4, image 1 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: step 4, image 2 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use the tip of a spudger to peel up the edge of the tape covering the button ribbon cable.
    • Use tweezers or your fingers to peel the tape up from the rear case, and remove it from the iPod.
Andrew Optimus Goldheart
503,396 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,457 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 98
