iPad Mini CDMA Antenna Cable Tape Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini CDMA Antenna Cable Tape Replacement, Antenna Cable Tape: step 1, image 1 of 2 iPad Mini CDMA Antenna Cable Tape Replacement, Antenna Cable Tape: step 1, image 2 of 2
    • Use the tip of a spudger to peel back the small piece of tape covering both antenna cables located near the bottom right corner of the iPad.
    • Leave the lower part of the tape stuck to the back of the rear case to aid in reassembly.
  2. iPad Mini CDMA Antenna Cable Tape Replacement: step 2, image 1 of 3 iPad Mini CDMA Antenna Cable Tape Replacement: step 2, image 2 of 3 iPad Mini CDMA Antenna Cable Tape Replacement: step 2, image 3 of 3
    • With the tip of a spudger, peel up the larger piece of tape covering both antenna cables near the bottom of the rear case.
    • Do not try to remove this piece of tape; it is wrapped around the top antenna cable.
Andrew Optimus Goldheart
503,352 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 122
