iPad 2 GSM Headphone Jack Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad 2 GSM Headphone Jack Assembly Replacement, Headphone Jack Assembly: step 1, image 1 of 3 iPad 2 GSM Headphone Jack Assembly Replacement, Headphone Jack Assembly: step 1, image 2 of 3 iPad 2 GSM Headphone Jack Assembly Replacement, Headphone Jack Assembly: step 1, image 3 of 3
    • Use the flat end of a plastic opening tool to flip up the retaining flap on the headphone jack and front-facing camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Run a plastic opening tool underneath the headphone jack and front-facing camera cable to free it from the adhesive attaching the cable to the rear panel.
    • Pull the headphone jack and front-facing camera ribbon cable straight out of its socket on the logic board.
  2. iPad 2 GSM Headphone Jack Assembly Replacement: step 2, image 1 of 1
    • Remove the three 2 mm Phillips screws securing the SIM slot to the rear panel.
  3. iPad 2 GSM Headphone Jack Assembly Replacement: step 3, image 1 of 1
    • Remove the two 2.9 mm Phillips screws securing the headphone jack to the rear panel.
  4. iPad 2 GSM Headphone Jack Assembly Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to help pull the headphone jack away from its recess in the top edge of the iPad.
    • Don't try to remove the assembly just yet.
  5. iPad 2 GSM Headphone Jack Assembly Replacement: step 5, image 1 of 1
    • Carefully peel the front camera and microphone cables off the rear panel.
  6. iPad 2 GSM Headphone Jack Assembly Replacement: step 6, image 1 of 2 iPad 2 GSM Headphone Jack Assembly Replacement: step 6, image 2 of 2
    • Carefully remove the strip of tape covering the front camera cable connector.
    • Use the edge of a plastic opening tool to disconnect the front camera cable from the headphone jack cable.
  7. iPad 2 GSM Headphone Jack Assembly Replacement: step 7, image 1 of 1
    • Carefully peel the front camera cable off the bottom ribbon cable attached to the headphone jack.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 817
