iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement, Rear Display Bezel: step 1, image 1 of 1
    • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  2. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: step 2, image 1 of 1
    • Use your thumbs to slightly separate the rear bezel from the front bezel.
    • It is helpful to hold the opposing corner of the display stationary to aid in flexing the rear bezel away from the display.
  3. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: step 3, image 1 of 3 iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: step 3, image 2 of 3 iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: step 3, image 3 of 3
    • Insert the flat end of a spudger into the gap between the front and rear bezels.
    • Rotate your spudger until it is parallel to the front face of the display.
    • Run the spudger around the perimeter of the display to separate the rear bezel from its retaining clips.
  4. iBook G4 12" 800 MHz-1.2 GHz Rear Display Bezel Replacement: step 4, image 1 of 1
    • Lift the rear bezel off the display.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 544
