Zune Flash 2nd Generation Back Cover Replacement
  1. Zune Flash 2nd Generation Back Cover Replacement, Back Cover: step 1, image 1 of 2 Zune Flash 2nd Generation Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Zune Flash 2nd Generation Back Cover Replacement: step 2, image 1 of 2 Zune Flash 2nd Generation Back Cover Replacement: step 2, image 2 of 2
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. Zune Flash 2nd Generation Back Cover Replacement: step 3, image 1 of 1
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
  4. Zune Flash 2nd Generation Back Cover Replacement: step 4, image 1 of 3 Zune Flash 2nd Generation Back Cover Replacement: step 4, image 2 of 3 Zune Flash 2nd Generation Back Cover Replacement: step 4, image 3 of 3
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  5. Zune Flash 2nd Generation Back Cover Replacement: step 5, image 1 of 3 Zune Flash 2nd Generation Back Cover Replacement: step 5, image 2 of 3 Zune Flash 2nd Generation Back Cover Replacement: step 5, image 3 of 3
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
ybahman
139 Reputation
4 Guides authored
Cal Poly, Team 9-20, Regan Fall 2009 Member of Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 3,707
