Xbox 360 Optical Drive Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Xbox 360 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Peel the silver tape securing the optical drive to the metal casing.
  2. Xbox 360 Optical Drive Replacement: step 2, image 1 of 1
    • Slightly lift the optical drive upwards to gain clearance to disconnect the SATA and power connectors located on the backside of the optical drive.
    • Don't try to completely remove the optical drive just yet. Two cables still connect it to the motherboard.
  3. Xbox 360 Optical Drive Replacement: step 3, image 1 of 2 Xbox 360 Optical Drive Replacement: step 3, image 2 of 2
    • Grab the power connector by its cables and pull it straight out of its socket on the optical drive.
    • Disconnect the SATA data connector from its socket on the optical drive by pulling it straight away.
  4. Xbox 360 Optical Drive Replacement: step 4, image 1 of 1
    • Lift the optical drive assembly out of the metal casing.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 1,772
