Xbox 360 Faceplate Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Xbox 360 Faceplate Replacement, Faceplate: step 1, image 1 of 2 Xbox 360 Faceplate Replacement, Faceplate: step 1, image 2 of 2
    • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
    • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
  2. Xbox 360 Faceplate Replacement: step 2, image 1 of 1
    • Repeat the same motions as previously mentioned to release the left side of the faceplate.
  3. Xbox 360 Faceplate Replacement: step 3, image 1 of 1
    • Remove the faceplate from the front face of the console.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 56
All Time: 1,068
