Venturer CR20 Speaker Replacement
  1. Venturer CR20 Speaker Replacement, Front Screen: step 1, image 1 of 1
    • On the bottom of the clock locate and unscrew the single 2mm Phillips screw from bottom of the clock.
  2. Venturer CR20 Speaker Replacement: step 2, image 1 of 2 Venturer CR20 Speaker Replacement: step 2, image 2 of 2
    • Using a moderate amount of force, position the screwdriver in the crack between the front screen and the main body of the clock (as shown) and push the screen away from the main body of the clock.
  3. Venturer CR20 Speaker Replacement, Power Cord: step 3, image 1 of 2 Venturer CR20 Speaker Replacement, Power Cord: step 3, image 2 of 2
    • Get a firm grip on the outside of the clock and a firm grip on the hardware on the inside of the the clock like so and pull the hardware out from the outside of the clock.
  4. Venturer CR20 Speaker Replacement: step 4, image 1 of 3 Venturer CR20 Speaker Replacement: step 4, image 2 of 3 Venturer CR20 Speaker Replacement: step 4, image 3 of 3
    • Using your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
  5. Venturer CR20 Speaker Replacement, Tuner Wheel: step 5, image 1 of 1
    • Just as before, pull the speaker plug directly up to remove the plug from the motherboard.
  6. Venturer CR20 Speaker Replacement: step 6, image 1 of 2 Venturer CR20 Speaker Replacement: step 6, image 2 of 2
    • Applying a bit of pressure at each of the contact points (illustrated by red circles), disconnect the display from the plastic housing.
  7. Venturer CR20 Speaker Replacement: step 7, image 1 of 3 Venturer CR20 Speaker Replacement: step 7, image 2 of 3 Venturer CR20 Speaker Replacement: step 7, image 3 of 3
    • Do not pull the plastic frame and motherboard apart too hard or the motherboard and plastic frame will not go back together.
    • Flip the motherboard over and push in each of the black clips to disconnect the plastic frame from the motherboard.
    • Proceed to remove the plastic frame gently, being cautious to not fully break the two apart.
  8. Venturer CR20 Speaker Replacement: step 8, image 1 of 3 Venturer CR20 Speaker Replacement: step 8, image 2 of 3 Venturer CR20 Speaker Replacement: step 8, image 3 of 3
    • Gently, pull the tuner wheel up and away from the motherboard.
  9. Venturer CR20 Speaker Replacement, Speaker: step 9, image 1 of 3 Venturer CR20 Speaker Replacement, Speaker: step 9, image 2 of 3 Venturer CR20 Speaker Replacement, Speaker: step 9, image 3 of 3
    • Flip over the motherboard and grab hold of the plastic frame.
    • With a small amount of force, push on the plastic clips, away from you, to eject the speaker from its plastic housing.
Robert Myers
54 Reputation
5 Guides authored
Cal Poly, Team 5-15, Forte Winter 2013 Member of Cal Poly, Team 5-15, Forte Winter 2013
CPSU-FORTE-W13S5G15
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 367
