Tools
Parts
No parts required.
Power down the TiVo and detach the power cable from the rear of the unit.
Remove the five T10 screws from the rear of the case using the Torx screwdriver.
Lift up and pull back the outer casing towards the rear of the unit.
I have the TiVo Series 2 model TCD746500 and the procedure for replacing a fan on my model is almost identical to the procedure described here, with one significant difference at this step: first pull/slide the outer casing back towards yourself and only thereafter pull it up.
Disconnect the power to the hard drive.
Grab the hard drive data cable from both sides of the connector and unplug it from the hard drive.
Unscrew the two screws on the case of the hard drive with a T10 screwdriver.
Pull the hard drive up and out of the TiVo unit.
Unscrew the four screws, shown in the picture, with a T-10 screwdriver.
Remove the hard drive from the case.
2 other people completed this guide.
