Sony Cyber-shot DSC-P9 Flash Replacement
  1. Sony Cyber-shot DSC-P9 Flash Replacement, Battery: step 1, image 1 of 1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Flash Replacement: step 2, image 1 of 1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Flash Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 3, image 2 of 2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Flash Replacement, Outer Casing: step 4, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement, Outer Casing: step 4, image 2 of 2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Flash Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 5, image 2 of 2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Flash Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 6, image 2 of 2
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Flash Replacement: step 7, image 1 of 1
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Flash Replacement, Lens: step 8, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement, Lens: step 8, image 2 of 2
    • Dislodge the round casing from the lens.
    • Pull it away from the rest of the camera.
  9. Sony Cyber-shot DSC-P9 Flash Replacement: step 9, image 1 of 1
    • Unscrew the two 4.0mm Phillips #000 screws from the display.
  10. Sony Cyber-shot DSC-P9 Flash Replacement: step 10, image 1 of 1
    • Pull the two ribbon cables out of their slots on the back circuit board.
  11. Sony Cyber-shot DSC-P9 Flash Replacement: step 11, image 1 of 1
    • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
  12. Sony Cyber-shot DSC-P9 Flash Replacement: step 12, image 1 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 12, image 2 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 12, image 3 of 3
    • Work the back panel out from under the small grey clip.
    • Slide the back panel off of the camera by dislodging it from the remaining clips.
    • Below is a flat, orange cable connecting the lens to the motherboard.
    • Be careful not to bend the back plate during this process.
  13. Sony Cyber-shot DSC-P9 Flash Replacement: step 13, image 1 of 1
    • Turn the camera over so that you can see the front of the lens.
    • Two connectors link the lens to the motherboard.
    • Gently bring the lens away from the camera.
  14. Sony Cyber-shot DSC-P9 Flash Replacement: step 14, image 1 of 1
    • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
    • Be careful not to exert too much force, as the connectors are delicate.
  15. Sony Cyber-shot DSC-P9 Flash Replacement: step 15, image 1 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 15, image 2 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 15, image 3 of 3
    • Gently pull out the cables and move the lens away from the rest of the camera.
    • You should now have two distinct, separate components.
  16. Sony Cyber-shot DSC-P9 Flash Replacement, Flash: step 16, image 1 of 1
    • Remove the 3.0mm Phillips #000 screw at the top of the battery door.
  17. Sony Cyber-shot DSC-P9 Flash Replacement: step 17, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 17, image 2 of 2
    • Pull off the top button piece. You will have to detach a small blue ribbon cable.
  18. Sony Cyber-shot DSC-P9 Flash Replacement: step 18, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 18, image 2 of 2
    • Caution: the capacitor, a black cylinder near the top of the camera, might have a charge in it, which could be harmful to you or the camera. Neutralize it by touching both wires with a screwdriver at the same time.
  19. Sony Cyber-shot DSC-P9 Flash Replacement: step 19, image 1 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 19, image 2 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 19, image 3 of 3
    • Remove the flash mechanism. It is held in place by a clip on the side of the camera.
    • The capacitor and flash will rotate out, still attached by a ribbon cable on the left.
  20. Sony Cyber-shot DSC-P9 Flash Replacement: step 20, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 20, image 2 of 2
    • Lift up the black tab with the spudger.
    • Gently remove the ribbon cable from the rest of the camera.
    • The flash component is now completely separate from the rest of the camera.
Andrew Forster
12 Reputation
2 Guides authored
Cal Poly, Team 17-25, Amido Spring 2012 Member of Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 713
