Sanyo Katana Screen Protector Replacement
  1. Sanyo Katana Screen Protector Replacement, Screen Protector: step 1, image 1 of 2 Sanyo Katana Screen Protector Replacement, Screen Protector: step 1, image 2 of 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Screen Protector Replacement: step 2, image 1 of 2 Sanyo Katana Screen Protector Replacement: step 2, image 2 of 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Screen Protector Replacement: step 3, image 1 of 2 Sanyo Katana Screen Protector Replacement: step 3, image 2 of 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
StephenYH
20 Reputation
3 Guides authored
Clemson, Team 12-1, Benson Spring 2013 Member of Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 319
