Samsung Epic 4G Touch Motherboard Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Samsung Epic 4G Touch Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 2 Samsung Epic 4G Touch Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 2 of 2
    • Use the flat end of a spudger to disconnect the front-facing camera cable connector.
  2. Samsung Epic 4G Touch Motherboard Assembly Replacement: step 2, image 1 of 1
    • Carefully disconnect the digitizer display cable.
  3. Samsung Epic 4G Touch Motherboard Assembly Replacement: step 3, image 1 of 1
    • Use a spudger to disconnect the display cable connector.
  4. Samsung Epic 4G Touch Motherboard Assembly Replacement: step 4, image 1 of 1
    • Remove the two 3 mm Phillips #00 screws.
  5. Samsung Epic 4G Touch Motherboard Assembly Replacement: step 5, image 1 of 3 Samsung Epic 4G Touch Motherboard Assembly Replacement: step 5, image 2 of 3 Samsung Epic 4G Touch Motherboard Assembly Replacement: step 5, image 3 of 3
    • Lift the micro-USB end of the motherboard away from the display assembly and pull it down.
    • Be mindful that you don't snag the motherboard on any cables as you remove it.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 62
