Raleigh M20 Handlebars Replacement
  1. Raleigh M20 Handlebars Replacement, Handlebars: step 1, image 1 of 2 Raleigh M20 Handlebars Replacement, Handlebars: step 1, image 2 of 2
    • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
    • Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
  2. Raleigh M20 Handlebars Replacement: step 2, image 1 of 3 Raleigh M20 Handlebars Replacement: step 2, image 2 of 3 Raleigh M20 Handlebars Replacement: step 2, image 3 of 3
    • Place an Allen wrench (size doesn't matter) under the bike grip.
    • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
  3. Raleigh M20 Handlebars Replacement: step 3, image 1 of 2 Raleigh M20 Handlebars Replacement: step 3, image 2 of 2
    • Slide off the gear shifters.
    • Slide off the brake controls.
  4. Raleigh M20 Handlebars Replacement: step 4, image 1 of 3 Raleigh M20 Handlebars Replacement: step 4, image 2 of 3 Raleigh M20 Handlebars Replacement: step 4, image 3 of 3
    • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
    • Lift the handlebars from the bike frame.
    • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
    • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
Jon Ribera
72 Reputation
1 Guide authored
Cal Poly, Team 7-49, Forte Fall 2012 Member of Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 41
All Time: 2,432
