PSP Go Battery Replacement
  1. PSP Go Battery Replacement, Back Cover: step 1, image 1 of 2 PSP Go Battery Replacement, Back Cover: step 1, image 2 of 2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Battery Replacement: step 2, image 1 of 2 PSP Go Battery Replacement: step 2, image 2 of 2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. PSP Go Battery Replacement, Top Cover: step 3, image 1 of 1
    • Pull the top cover upwards gently from its housing.
  4. PSP Go Battery Replacement, Left Trigger: step 4, image 1 of 1
    • Use a plastic opening tool to gently flip up the left trigger connector.
  5. PSP Go Battery Replacement: step 5, image 1 of 2 PSP Go Battery Replacement: step 5, image 2 of 2
    • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
    • If necessary, repeat steps 2 and 3 to remove the right trigger button.
  6. PSP Go Battery Replacement, Battery: step 6, image 1 of 3 PSP Go Battery Replacement, Battery: step 6, image 2 of 3 PSP Go Battery Replacement, Battery: step 6, image 3 of 3
    • Do not peel the sticker away from the left EMI shield. It will expose the "VOID VOID" lettering that will void your warranty!
    • Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
  7. PSP Go Battery Replacement: step 7, image 1 of 1
    • Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
    • Wedge a plastic opening tool in between the connector and logic board, and gently pull the connector upwards.
    • Make sure not to disconnect the white connector socket on the logic board, and just the connector itself.
  8. PSP Go Battery Replacement: step 8, image 1 of 2 PSP Go Battery Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to pop out the battery, being careful not to snag the "Warranty Void" sticker in the process.
    • When putting a new battery into the PSP Go, make sure you hold the "Warranty Sticker" so you don't put the battery on top of it.
22 other people completed this guide.
12 Guide Comments
this was so quick . I have been trying to get this repaired for years, only to hear throw it away there is no fix . sharing love
mainemade4u - Reply
a couple of notes my cover came completely off in the beginning step without a problem or broken screws. next i didnt und the wired cabled beside the clicker and it wasnt in the way.
mainemade4u - Reply
After replace a new battery my psp go going crazy. Charge only 1 or 2 min led going to green but not fully charge. Anyone can help me to fix this
Mus Mohamed - Reply
Cfw 6.61 pro update. Helppp
Mus Mohamed - Reply
Thanks to this guide I was able to reseat the battery, the PSP was not turning on or charging any more, now everything is working again.
Marvin Arand - Reply
Past 24 Hours: 15
Past 7 Days: 128
Past 30 Days: 427
All Time: 102,305
