Nokia 2128i Motherboard Assembly Replacement
  1. Nokia 2128i Motherboard Assembly Replacement, Battery: step 1, image 1 of 3 Nokia 2128i Motherboard Assembly Replacement, Battery: step 1, image 2 of 3 Nokia 2128i Motherboard Assembly Replacement, Battery: step 1, image 3 of 3
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Motherboard Assembly Replacement: step 2, image 1 of 3 Nokia 2128i Motherboard Assembly Replacement: step 2, image 2 of 3 Nokia 2128i Motherboard Assembly Replacement: step 2, image 3 of 3
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Motherboard Assembly Replacement, Faceplate: step 3, image 1 of 3 Nokia 2128i Motherboard Assembly Replacement, Faceplate: step 3, image 2 of 3 Nokia 2128i Motherboard Assembly Replacement, Faceplate: step 3, image 3 of 3
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Motherboard Assembly Replacement, Keypad: step 4, image 1 of 3 Nokia 2128i Motherboard Assembly Replacement, Keypad: step 4, image 2 of 3 Nokia 2128i Motherboard Assembly Replacement, Keypad: step 4, image 3 of 3
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Motherboard Assembly Replacement, Motherboard Assembly: step 5, image 1 of 3 Nokia 2128i Motherboard Assembly Replacement, Motherboard Assembly: step 5, image 2 of 3 Nokia 2128i Motherboard Assembly Replacement, Motherboard Assembly: step 5, image 3 of 3
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Motherboard Assembly Replacement: step 6, image 1 of 3 Nokia 2128i Motherboard Assembly Replacement: step 6, image 2 of 3 Nokia 2128i Motherboard Assembly Replacement: step 6, image 3 of 3
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
Chad
19 Reputation
5 Guides authored
Cal Poly, Team 20-8, Maness Fall 2010 Member of Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Members
24 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 1,487
