Nokia 1100b RH-36 Keypad Replacement
  1. Nokia 1100b RH-36 Keypad Replacement, Removing Nokia 1100b RH-36 Front Cover: step 1, image 1 of 2 Nokia 1100b RH-36 Keypad Replacement, Removing Nokia 1100b RH-36 Front Cover: step 1, image 2 of 2
    • Firmly grip the back of the casing.
    • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
    • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
  2. Nokia 1100b RH-36 Keypad Replacement, Keypad: step 2, image 1 of 1
    • Using the flat end of the spudger, push out the 4 rubber tabs on the back of the keypad to remove it.
3 other people completed this guide.
JSwan
751 Reputation
6 Guides authored
Cal Poly, Team 10-43, Amido Spring 2013 Member of Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,880
