Nintendo DSi XL Stylus Housing Replacement
  1. Nintendo DSi XL Stylus Housing Replacement, Battery: step 1, image 1 of 2 Nintendo DSi XL Stylus Housing Replacement, Battery: step 1, image 2 of 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Stylus Housing Replacement: step 2, image 1 of 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Stylus Housing Replacement, Lower Case: step 3, image 1 of 3 Nintendo DSi XL Stylus Housing Replacement, Lower Case: step 3, image 2 of 3 Nintendo DSi XL Stylus Housing Replacement, Lower Case: step 3, image 3 of 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Stylus Housing Replacement: step 4, image 1 of 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Stylus Housing Replacement: step 5, image 1 of 3 Nintendo DSi XL Stylus Housing Replacement: step 5, image 2 of 3 Nintendo DSi XL Stylus Housing Replacement: step 5, image 3 of 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Stylus Housing Replacement: step 6, image 1 of 2 Nintendo DSi XL Stylus Housing Replacement: step 6, image 2 of 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Stylus Housing Replacement: step 7, image 1 of 2 Nintendo DSi XL Stylus Housing Replacement: step 7, image 2 of 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: step 8, image 1 of 3 Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: step 8, image 2 of 3 Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: step 8, image 3 of 3
    • Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
    • Lift the right shoulder button assembly from the back case.
    • The components of the right shoulder button assembly:
    • Right shoulder button
    • Shoulder button spring
    • Retaining pin
    • Right shoulder button holding panel
  9. Nintendo DSi XL Stylus Housing Replacement, Stylus Housing: step 9, image 1 of 1
    • Remove the stylus from its housing on the right side of the DSi XL.
  10. Nintendo DSi XL Stylus Housing Replacement: step 10, image 1 of 3 Nintendo DSi XL Stylus Housing Replacement: step 10, image 2 of 3 Nintendo DSi XL Stylus Housing Replacement: step 10, image 3 of 3
    • Remove the three 4 mm gold Phillips screws securing the stylus housing to the lower case.
    • Using a spudger, lift the stylus housing off the lower case.
    • Remove the stylus housing from the handheld console.
4 other people completed this guide.
Brett Hartt
128,087 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,680 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 7,779
