MacBook Air 11" Late 2010 Logic Board Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Air 11" Late 2010 Logic Board Replacement, Logic Board: step 1, image 1 of 1
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  2. MacBook Air 11" Late 2010 Logic Board Replacement: step 2, image 1 of 2 MacBook Air 11" Late 2010 Logic Board Replacement: step 2, image 2 of 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  3. MacBook Air 11" Late 2010 Logic Board Replacement: step 3, image 1 of 1
    • Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
  4. MacBook Air 11" Late 2010 Logic Board Replacement: step 4, image 1 of 1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry up from beneath the cables.
  5. MacBook Air 11" Late 2010 Logic Board Replacement: step 5, image 1 of 3 MacBook Air 11" Late 2010 Logic Board Replacement: step 5, image 2 of 3 MacBook Air 11" Late 2010 Logic Board Replacement: step 5, image 3 of 3
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  6. MacBook Air 11" Late 2010 Logic Board Replacement: step 6, image 1 of 1
    • Remove the small rubber gasket from the corner of the upper case near the display data cable.
  7. MacBook Air 11" Late 2010 Logic Board Replacement: step 7, image 1 of 2 MacBook Air 11" Late 2010 Logic Board Replacement: step 7, image 2 of 2
    • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
  8. MacBook Air 11" Late 2010 Logic Board Replacement: step 8, image 1 of 1
    • Gently de-route the antenna cables from the slot cut into the logic board.
  9. MacBook Air 11" Late 2010 Logic Board Replacement: step 9, image 1 of 1
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
  10. MacBook Air 11" Late 2010 Logic Board Replacement: step 10, image 1 of 1
    • Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 350
