Introduction
Hook-and-loop tape, also known by the common brand, Velcro, is a widely used fastener for clothing of all types. The hook-and-loop tape on your clothing provides a reliable way to close two pieces of fabric together without much hassle. This guide shows you how to sew hook-and-loop tape onto your fabric. If you have worn out hook-and-loop tape that needs to be replaced, you can use these same directions, but simply remove the stitches on your old hook-and-loop tape first, by using a seam ripper.In this guide we are using contrasting thread for visibility. When it comes time to do your actual project, you'll want to use thread that matches the color of your hook-and-loop tape.
For replacement parts or further assistance, contact Patagonia Customer Service.
Lay your piece of hook-and-loop tape on the fabric where you would like it to live.
Pin the hook-and-loop tape into place.
Position your fabric under the presser foot of your sewing machine in the upper right hand corner of the hook-and-loop tape. Drop the presser foot.
Use the balance wheel to sink the needle.
Clip the threads, freeing the fabric from the sewing machine.
Clip the extra thread off.
Repeat this guide for the other side of the hook-and-loop tape.
Ist es besser wenn man doppelt näht?
Oder reicht es einmal?
Ich denke weil es oft beansprucht wird sollte man doppelt annähern.
