HP Pavilion zd8000 RAM Replacement
  1. HP Pavilion zd8000 RAM Replacement, Battery: step 1, image 1 of 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 RAM Replacement: step 2, image 1 of 2 HP Pavilion zd8000 RAM Replacement: step 2, image 2 of 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 RAM Replacement, RAM: step 3, image 1 of 2 HP Pavilion zd8000 RAM Replacement, RAM: step 3, image 2 of 2
    • Loosen the Phillips screw labeled ‘ram’ and lift the cover.
  4. HP Pavilion zd8000 RAM Replacement: step 4, image 1 of 2 HP Pavilion zd8000 RAM Replacement: step 4, image 2 of 2
    • Locate the green RAM card and find the metal tabs securing the card.
    • Push outwards on the two tabs to release the card.
  5. HP Pavilion zd8000 RAM Replacement: step 5, image 1 of 1
    • Carefully slide the card out at an upward angle away from the slot.
4 other people completed this guide.
Allie Menard
820 Reputation
13 Guides authored
Cal Poly, Team 24-56, Amido Spring 2011 Member of Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 16
All Time: 7,362
