HP Mini 311 RAM Replacement
  1. HP Mini 311 RAM Replacement, Battery: step 1, image 1 of 3 HP Mini 311 RAM Replacement, Battery: step 1, image 2 of 3 HP Mini 311 RAM Replacement, Battery: step 1, image 3 of 3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 RAM Replacement: step 2, image 1 of 2 HP Mini 311 RAM Replacement: step 2, image 2 of 2
    • Slide the battery away from the device to remove.
  3. HP Mini 311 RAM Replacement, Memory Shield: step 3, image 1 of 1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 RAM Replacement: step 4, image 1 of 2 HP Mini 311 RAM Replacement: step 4, image 2 of 2
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 RAM Replacement, RAM: step 5, image 1 of 3 HP Mini 311 RAM Replacement, RAM: step 5, image 2 of 3 HP Mini 311 RAM Replacement, RAM: step 5, image 3 of 3
    • Firmly press on the metal pins located on both sides of the RAM.
    • One side of the RAM will pop up to form a 40 degree angle with the body of the laptop.
    • Simply grab and remove the RAM from the device.
2 other people completed this guide.
Christian Santoyo
495 Reputation
6 Guides authored
Cal Poly, Team 20-4, Maness Winter 2013 Member of Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Members
6 Guides authored
2 Comments
4 GB modules are not supported it seems.
You may see posts in the HP Support Forum saying that the Mini 311 will accept a 4 GB module. Possibly this is true for the Pavilion DM, but not the Mini 311.
The service manual says only 2GB or 1 GB are supported.
Other people posted that they tried a 4GB module and it did not work.
rafss - Reply
FYI, The link to buy the suggested part is wrong and not compatible.
Christine Fowler - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 3,688
