Canon Powershot SD550 LCD Screen Replacement
  1. Canon Powershot SD550 LCD Screen Replacement, Outer Case: step 1, image 1 of 1
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 LCD Screen Replacement: step 2, image 1 of 1
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 LCD Screen Replacement: step 3, image 1 of 3 Canon Powershot SD550 LCD Screen Replacement: step 3, image 2 of 3 Canon Powershot SD550 LCD Screen Replacement: step 3, image 3 of 3
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 LCD Screen Replacement: step 4, image 1 of 3 Canon Powershot SD550 LCD Screen Replacement: step 4, image 2 of 3 Canon Powershot SD550 LCD Screen Replacement: step 4, image 3 of 3
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 LCD Screen Replacement: step 5, image 1 of 3 Canon Powershot SD550 LCD Screen Replacement: step 5, image 2 of 3 Canon Powershot SD550 LCD Screen Replacement: step 5, image 3 of 3
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 LCD Screen Replacement: step 6, image 1 of 3 Canon Powershot SD550 LCD Screen Replacement: step 6, image 2 of 3 Canon Powershot SD550 LCD Screen Replacement: step 6, image 3 of 3
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
  7. Canon Powershot SD550 LCD Screen Replacement, LCD Screen: step 7, image 1 of 3 Canon Powershot SD550 LCD Screen Replacement, LCD Screen: step 7, image 2 of 3 Canon Powershot SD550 LCD Screen Replacement, LCD Screen: step 7, image 3 of 3
    • Peel the navigation buttons from the button panel and set them aside.
    • To free the LCD display, remove the 2.9 mm screw in the top left corner.
    • Rotate the screen clockwise until it lifts away from the camera.
    • There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
  8. Canon Powershot SD550 LCD Screen Replacement: step 8, image 1 of 2 Canon Powershot SD550 LCD Screen Replacement: step 8, image 2 of 2
    • To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
    • After disconnecting both cables, pull the screen away from the camera to remove it.
2 other people completed this guide.
Vivian Su
31 Reputation
1 Guide authored
Cal Poly, Team 18-23, Garner Spring 2011 Member of Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
5 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 3,590
