Acer AL1916 Outer Case Replacement
  1. Acer AL1916 Outer Case Replacement, Stand: step 1, image 1 of 1
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Outer Case Replacement: step 2, image 1 of 2 Acer AL1916 Outer Case Replacement: step 2, image 2 of 2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Outer Case Replacement: step 3, image 1 of 2 Acer AL1916 Outer Case Replacement: step 3, image 2 of 2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
  4. Acer AL1916 Outer Case Replacement, Outer Case: step 4, image 1 of 2 Acer AL1916 Outer Case Replacement, Outer Case: step 4, image 2 of 2
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
  5. Acer AL1916 Outer Case Replacement: step 5, image 1 of 3 Acer AL1916 Outer Case Replacement: step 5, image 2 of 3 Acer AL1916 Outer Case Replacement: step 5, image 3 of 3
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
  6. Acer AL1916 Outer Case Replacement: step 6, image 1 of 2 Acer AL1916 Outer Case Replacement: step 6, image 2 of 2
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
Keith
351 Reputation
4 Guides authored
Cal Poly, Team 20-26, Maness Fall 2011 Member of Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 16
All Time: 1,245
