Introduction
La sostituzione della batteria dei MacBook Unibody è un'operazione semplice.
Con il case chiuso, posizionare l'Unibody capovolto su una superficie piatta.
Premere il lato scanalato della chiusura di sgancio dello sportello di accesso, affinché sia possibile prendere l'estremità libera con le mani. Sollevare la chiusura di sgancio finché non è in posizione verticale.
Prendere la linguetta di plastica bianca ed estrarre la batteria, rimuovendola dall'Unibody.
Per riassemblare il dispositivo, seguire queste istruzioni in ordine inverso.
93 other people completed this guide.
Special thanks to these translators:
100%
Jasper Fleischhauer is helping us fix the world! Want to contribute?
Start translating ›
15 Comments
The battery in my Unibody Macbook won't come out. I've tried everything. While it does move from side to side a little bit I am completely unable to remove it.
This is not an A1278 MacBook. I have one Infront of me and it uses a different battery and is attached entirely with screws not some access door.
This is not the unibody A1278 model, that battery is internal and the back cover has to come off.
I agree. Working on mine now. It’s quite different than this example. I hope examples of other repairs are more precise. I have at least the fan and heat sink left to do. Maybe more if it continues to overheat.
This is exactly like my A1278 Macbook unibody and the replacement process was exactly like this. Took one minute. Thanks!!
