Introduction
Le retrait de la RAM est une opération simple qui ne nécessite pas d'outils.
Placez vos pouces dans les deux creux du capot inférieur.
Faites pivoter le capot inférieur dans le sens contraire des aiguilles d'une montre jusqu'à ce que le petit point blanc peint sur le capot soit aligné sur le repère correspondant du boîtier extérieur.
Écartez les deux clips de chaque côté de la barrette de RAM simultanément pour libérer cette dernière.
Lorsque la barrette de RAM se soulève, sortez-la de son emplacement en la levant bien droit.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
181 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
7 Comments
So if I were to replace the Ram on my mac mini I would only have the option to choose between the 2 gb chip or the 4gb chip? I know dumb question lol.
2x8GB is as much as those motherboards can handle.
Dear everyone,
Does this mac mini accept :
KINGSTON DDR3 PC3-12800 - 2 x 4 Go (8 Go) 1600 MHZ - CAS 10 - HyperX Fury Black Series
Thank you.
I always consult Crucial's memory configuration tool. For a late-2012 Mac mini, see http://www.crucial.com/usa/en/compatible....
According to them, this Mac can go up to 16GB (2 SO-DIMMs of 8GB each). The SO-DIMMs should be DDRL3L-1600 (DDR3L PC3L-12800, CL=11, unbuffered, non-ECC, DDR3L-1600, 1.35v)
The SO-DIMMs you mentioned seem like they should be compatible (CL=10 should work fine in a computer that can accept CL=11). But I would only buy from a vendor that has a compatibility guarantee. If there's a problem, I would want to be able to return them for a refund.
The SODIMMs don't need to be low voltage DDR3L (i.e. 1.35 volt). In fact Apple recommends (https://support.apple.com/en-gb/HT202593) regular 1.5 volt DDR3 and most late 2012 Mac Minis were shipped with it. So is Crucial wrong? The truth is that either will work.
