Introduction
Avec ce tutoriel, remplacez un disque dur mort.
Video Overview
Retirez les dix vis suivantes :
Trois vis Phillips #00 14,4 mm
Trois vis Phillips #00 3,5 mm
Quatre vis à épaulement Phillips #00 3,5 mm
Quand vous replacerez les petites vis, alignez-les perpendiculairement à la légère courbe de la coque (elles ne se vissent pas à la verticale).
À l'aide de l'extrémité d'une spatule (spudger), faites levier sur le connecteur de la batterie pour le débrancher de la prise sur la carte mère.
Retirez les deux vis Phillips par lesquelles le support du disque dur est fixé au boîtier supérieur.
Retirez les quatre broches de fixation Torx 6 mm sur les côtés du disque dur.
Réutilisez ces vis sur le nouveau SSD.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
438 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
32 Comments
Under updated firmware, macbook pro unibody models will not recognize many third-party hard drives. See this discussion: https://discussions.apple.com/message/15...
Awesome guide! Swapped my 320GB hard drive for an 1TB hard drive. Took five mins thanks to iFixit!
hey, do you use SATA 3 for you’re MacBook Pro A1278? is it work good? no problems?
dimdimisra, you use the built in cable that comes in it, because of the proprietary mortherboard connector, you can’t use a regular SATA 3 cable
I feel you should be pointing out a couple of things about the chassis screws that are not obvious to the inexperienced
- the 6 screws that are not along the hinge edge of the body (4 yellow & 2 of the orange) are not perpendicular to the flat surface; they go in at an angle such that their heads are flat in the curve in which they sit. Attempting to hold the screwdriver upright in these heads could lead to damage to the screws, stripping out the "cross"
- attempting to insert these screws "straight" when reassembling will lead to cross-threading and stripping the screw threads
