Introduction
The Insignia 2-in-1 stick vacuum power button, over time, is prone to getting damaged or not working. The button may get jammed or the electrical components will stop working. In both cases, use this guide to fix or replace the power button.
Remove the four 12mm Phillips screws , and the one large 32mm Phillips head bolt from the vacuum handle.
Pull up on the back cover of the vacuum handle and remove it.
Remove the two 10mm Phillips #2 screws on the back of the green printed circuit board.
If the circuit board needs to be replaced, locate where the two white wires are soldered to the board, and de-solder the connection.
