Insignia NS-VCS14SL7 Power Button Replacement
  1. Insignia NS-VCS14SL7 Power Button Replacement, Battery: step 1, image 1 of 2 Insignia NS-VCS14SL7 Power Button Replacement, Battery: step 1, image 2 of 2
    • Push down the black button to release the dust cup.
    • Pull the dust cup up and away from handheld portion to remove.
  2. Insignia NS-VCS14SL7 Power Button Replacement: step 2, image 1 of 3 Insignia NS-VCS14SL7 Power Button Replacement: step 2, image 2 of 3 Insignia NS-VCS14SL7 Power Button Replacement: step 2, image 3 of 3
    • Remove the five 12.0 mm screws on the back of the handheld portion using the Phillips #2 screwdriver.
    • Lift the silver cover off of the black body of the handheld portion to expose the battery and wiring.
  3. Insignia NS-VCS14SL7 Power Button Replacement: step 3, image 1 of 2 Insignia NS-VCS14SL7 Power Button Replacement: step 3, image 2 of 2
    • Pull apart the red and black wires.
    • Do so for all of the wires. (Red x1, Black x2)
  4. Insignia NS-VCS14SL7 Power Button Replacement: step 4, image 1 of 1
    • Remove the tape holding the battery to the black housing.
    • Slide the entire battery bundle out.
  5. Insignia NS-VCS14SL7 Power Button Replacement, Handheld Vacuum Power Button: step 5, image 1 of 1
    • Remove motor and impeller housing to gain access to power button.
  6. Insignia NS-VCS14SL7 Power Button Replacement: step 6, image 1 of 2 Insignia NS-VCS14SL7 Power Button Replacement: step 6, image 2 of 2
    • Pry upwards on the retaining clip with black plastic spudger and pull to remove the 5 pin connector.
  7. Insignia NS-VCS14SL7 Power Button Replacement: step 7, image 1 of 2 Insignia NS-VCS14SL7 Power Button Replacement: step 7, image 2 of 2
    • Remove the two 10mm Philips #2 screws holding the brown printed circuit board to the vacuum.
    • Remove brown printed circuit board.
    • Pull up on clear plastic power button assembly to remove.
Thibaut Pillot
434 Reputation
5 Guides authored
USF Tampa, Team S16-G3, Boczar Spring 2018 Member of USF Tampa, Team S16-G3, Boczar Spring 2018
USFT-BOCZAR-S18S16G3
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 219
