Insignia NS-PLTPSP13 Disassembly
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Insignia NS-PLTPSP13 Disassembly, Insignia NS-PLTPSP13 Disassembly: step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to lift the corner of the mesh until a gap is created.
      Ask FixBot
    2. Insignia NS-PLTPSP13 Disassembly: step 2, image 1 of 2 Insignia NS-PLTPSP13 Disassembly: step 2, image 2 of 2
      • Once there is a gap big enough, insert the metal spudger, and remove the tweezers.
      Ask FixBot
    3. Insignia NS-PLTPSP13 Disassembly: step 3, image 1 of 3 Insignia NS-PLTPSP13 Disassembly: step 3, image 2 of 3 Insignia NS-PLTPSP13 Disassembly: step 3, image 3 of 3
      • Now take the size J0 JIS screwdriver to remove the seven 5 mm screws on the plastic casing of the speaker.
      • Do not forget about the 5mm screw on the backside of the speaker, it may be covered by a white sticker, and it will prevent you from removing the plastic cover.
      Ask FixBot
    4. Insignia NS-PLTPSP13 Disassembly: step 4, image 1 of 2 Insignia NS-PLTPSP13 Disassembly: step 4, image 2 of 2
      • Once all seven 5mm screws are taken off use the metal spudger again to pry off the plastic casing from the speaker.
      Ask FixBot
    5. Insignia NS-PLTPSP13 Disassembly: step 5, image 1 of 2 Insignia NS-PLTPSP13 Disassembly: step 5, image 2 of 2
      • To further take apart the speaker, there are also two 5mm screws on the green circuit board which keep the speaker and circuit board attached. Unscrew these with the size J0 JIS screwdriver.
      Ask FixBot
Madeleine
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 228
