Insignia NS-BCDCAS1 Outer Panels Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Insignia NS-BCDCAS1 Outer Panels Replacement, Outer Panels: step 1, image 1 of 2 Insignia NS-BCDCAS1 Outer Panels Replacement, Outer Panels: step 1, image 2 of 2
    • Turn the boombox around to see the back, and then flip it upside down.
    • Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
    • Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
  2. Insignia NS-BCDCAS1 Outer Panels Replacement: step 2, image 1 of 1
    • Peel off the two black square foams in front of the battery compartment to reveal a screw under each one.
  3. Insignia NS-BCDCAS1 Outer Panels Replacement: step 3, image 1 of 2 Insignia NS-BCDCAS1 Outer Panels Replacement: step 3, image 2 of 2
    • Remove the two 8mm screws using a 2.5mm flathead driver.
    • The front grey panel will loosen up once the final screw is removed.
  4. Insignia NS-BCDCAS1 Outer Panels Replacement: step 4, image 1 of 1
    • Turn the boombox on its back.
    • Release the front panel by pushing down on the latches holding the panels together.
    • There are four silver latches on the top side of the panel and one on the bottom.
    • Do not force the panel comletely off, there are cables attached inside.
  5. Insignia NS-BCDCAS1 Outer Panels Replacement: step 5, image 1 of 2 Insignia NS-BCDCAS1 Outer Panels Replacement: step 5, image 2 of 2
    • Turn the boombox around to view the back and lift the handle up.
    • Using the same driver with 2.5mm flathead, remove the two 14mm screws under the handle.
    • Gently lift the black top but do not pull completely away.
Cristina Ruiz
137 Reputation
1 Guide authored
CSU Fullerton, Team 2-5, Bruce Fall 2016 Member of CSU Fullerton, Team 2-5, Bruce Fall 2016
CSUF-BRUCE-F16S2G5
4 Members
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 37
