Shop the Holiday Gift Guide
Inner Frame
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
9
All Time:
268
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Inner Frame
Introduction
Go to step 1 ↓
In order to access the core components of the Acer Aspire One 725-0845, you will need to remove the inner frame, detailed here.
Tools
    1. Inner Frame, Battery: step 1, image 1 of 1
      • Ensure the device is powered off by holding down the power button on the top left-hand side.
      • On a flat, level surface, flip the device over so that the back-plate is accessible.
      Ask FixBot
    2. Inner Frame: step 2, image 1 of 3 Inner Frame: step 2, image 2 of 3 Inner Frame: step 2, image 3 of 3
      • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
      • Simultaneously pull the battery out and away from the device.
      Ask FixBot
    1. Inner Frame, Back Plate: step 3, image 1 of 3 Inner Frame, Back Plate: step 3, image 2 of 3 Inner Frame, Back Plate: step 3, image 3 of 3
      • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
      • Using your hands, slide the back-plate away from the center of the device and remove.
      Ask FixBot
    1. Inner Frame, Hard Drive: step 4, image 1 of 2 Inner Frame, Hard Drive: step 4, image 2 of 2
      • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
      Ask FixBot
    2. Inner Frame: step 5, image 1 of 1
      • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
      • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
      Ask FixBot
    1. Inner Frame, Inner Frame: step 6, image 1 of 3 Inner Frame, Inner Frame: step 6, image 2 of 3 Inner Frame, Inner Frame: step 6, image 3 of 3
      • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
      • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
      • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
      Ask FixBot
    2. Inner Frame: step 7, image 1 of 3 Inner Frame: step 7, image 2 of 3 Inner Frame: step 7, image 3 of 3
      • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
      • Gently remove the keyboard connection by pulling away from the center of the device.
      • Lift the black locks for the touchpad connections into the upward position.
      • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
      Ask FixBot
    3. Inner Frame: step 8, image 1 of 3 Inner Frame: step 8, image 2 of 3 Inner Frame: step 8, image 3 of 3
      • Flip the device over and open it.
      • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
      Ask FixBot
Author
with
Joe Kendall
361 Reputation
3 Guides authored
USF Tampa, Team 8-3, Eyestone Spring 2017 Member of USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 268
