Replacing Sega Dreamcast Power Block (Power Supply)
  1. Replacing Sega Dreamcast Power Block (Power Supply), Expansion Bay: step 1, image 1 of 2 Replacing Sega Dreamcast Power Block (Power Supply), Expansion Bay: step 1, image 2 of 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Replacing Sega Dreamcast Power Block (Power Supply): step 2, image 1 of 3 Replacing Sega Dreamcast Power Block (Power Supply): step 2, image 2 of 3 Replacing Sega Dreamcast Power Block (Power Supply): step 2, image 3 of 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Replacing Sega Dreamcast Power Block (Power Supply), Top Cover: step 3, image 1 of 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Replacing Sega Dreamcast Power Block (Power Supply): step 4, image 1 of 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Replacing Sega Dreamcast Power Block (Power Supply), Power Block (Power Supply): step 5, image 1 of 2 Replacing Sega Dreamcast Power Block (Power Supply), Power Block (Power Supply): step 5, image 2 of 2
    • Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working.
    • Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
  6. Replacing Sega Dreamcast Power Block (Power Supply): step 6, image 1 of 1
    • Remove the two 10mm Philips #02 screws that are fastened to the power block.
  7. Replacing Sega Dreamcast Power Block (Power Supply): step 7, image 1 of 2 Replacing Sega Dreamcast Power Block (Power Supply): step 7, image 2 of 2
    • Do not bend the male pin header between the mounted head when you remove the power supply from the chassis.
    • Remove the power board by using both hands to gently lift the power board away from the console.
  8. Replacing Sega Dreamcast Power Block (Power Supply): step 8, image 1 of 1
    • Remove the clear plastic film that is tucked between the power supply and the chassis.
8 other people completed this guide.
wkwong
533 Reputation
5 Guides authored
Cal Poly, Team 5-1, Regan Fall 2009 Member of Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Members
21 Guides authored
3 Comments
All symptoms of dead PSU can be occuring, if by accident flat ribbon cable between motherboard and controller board is disconnected. Check that cable if both ends is firmly plugged.
lauraiss lv - Reply
Hello There!
i turn on my dreamcast, No video, GD donĀ“t spin, but the orange led barely shine, this happened many years ago (2003) , i just bought another DC in those days because i was in a hurry to end Grandia 2, and now i still have the damaged console in my room and im wondering if it is possible to fix it ...thanks!
Mardito Online - Reply
Very good and Panico
Mikesin - Reply
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 72
All Time: 16,335
