Up to 20% off select tools
Infinity Genesis Footrest Slide Assembly Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
31
Past 30 Days:
68
All Time:
374
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Infinity Genesis Footrest Slide Assembly Replacement, Remove Rear Panel of footrest: step 1, image 1 of 1
      • Both panels come off together. Do not try to remove them individually.
      • Remove all 11 screws to remove the panels.
      Ask FixBot
    2. Infinity Genesis Footrest Slide Assembly Replacement: step 2, image 1 of 1
      • Once the rear covers are removed you will be able to see the inside of the extend cabinet.
      Ask FixBot
    3. Infinity Genesis Footrest Slide Assembly Replacement: step 3, image 1 of 1
      • Remove the 4 screws to release the extend cabinet from the front of the footrest
      • Remove the 4 screws to release the extend cabinet from the front of the calf massager
      Ask FixBot
    4. Infinity Genesis Footrest Slide Assembly Replacement: step 4, image 1 of 1
      • The extend cabinet should now be free of the front half of the footrest.
      • Remove the 5 screws to remove the front cover of the extend cabinet.
      Ask FixBot
    5. Infinity Genesis Footrest Slide Assembly Replacement: step 5, image 1 of 1
      • If the Feed Screw Nut needs to be replaced remove these 4 screws. They are held in by nuts that may need to be held when removing the screw
      Ask FixBot
    6. Infinity Genesis Footrest Slide Assembly Replacement: step 6, image 1 of 2 Infinity Genesis Footrest Slide Assembly Replacement: step 6, image 2 of 2
      • There are 4 screws holding the slides in place. To get access to each of them you would need to manually extend the footrest by spinning the motor.
      • Remove these 4 screws. Only 2 will be available at a time depending on how the slide it positioned.
      Ask FixBot
    7. Infinity Genesis Footrest Slide Assembly Replacement: step 7, image 1 of 1
      • The two halves of the extend cabinet will need to be separated at this point. Continue to spin the motor until the screw shaft is completely removed from the feed screw nut.
      • The two halves should be separated like this once done.
      Ask FixBot
    8. Infinity Genesis Footrest Slide Assembly Replacement: step 8, image 1 of 2 Infinity Genesis Footrest Slide Assembly Replacement: step 8, image 2 of 2
      • Remove the final 4 screws holding the slides in place.
      Ask FixBot
    9. Infinity Genesis Footrest Slide Assembly Replacement: step 9, image 1 of 1
      • The new slides need to be installed onto this plate first.
      • The nuts attached to the new slides are for transport purposes only. They will not be installed into the footrest
      • The new slides CAN NOT be stood up on their ends once the screws are removed. The internal components may slide out and ruin the slide. All movement has to be done to the side.
      Ask FixBot
Author
with
Mike Klessens
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 31
Past 30 Days: 68
All Time: 374
