InFocus IN3114 Top Plate Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
49
All Time:
414
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the top plate of the InFocus 3114.
The top plate may be cracked and need replacing, but more often, this component requires removal in order to provide access to other components of the device such as the projector, such as the lamp, fan, lens, and DMD chip.
Properly performing this step is vital in repairing other components of the device.
Tools
    1. InFocus IN3114 Top Plate Replacement, Top Plate: step 1, image 1 of 2 InFocus IN3114 Top Plate Replacement, Top Plate: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the 1.2 cm Phillips-head screw from each side of the projector.
      Ask FixBot
    2. InFocus IN3114 Top Plate Replacement: step 2, image 1 of 3 InFocus IN3114 Top Plate Replacement: step 2, image 2 of 3 InFocus IN3114 Top Plate Replacement: step 2, image 3 of 3
      • Use your hands to slide the top plate off of the projector.
      • Lift and remove the plate.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 49
All Time: 414
