Up to 20% off select tools
IT-Riage Rev 3 Cylinder Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
80
All Time:
407
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This will show you how to access the cylinders under the chair in order to grease the motors.
    1. IT-Riage Rev 3 Cylinder  Disassembly, IT-Riage Rev 3 Cylinder  Disassembly: step 1, image 1 of 2 IT-Riage Rev 3 Cylinder  Disassembly, IT-Riage Rev 3 Cylinder  Disassembly: step 1, image 2 of 2
      • This is what the chair will look like like without the footrest. to remove the footrest . You need to unplug the power cable and air hose behind the footrest . Then using a flat head screw driver remove the clips on either side by sliding the tip of screw driver in the clip and simultaneously lifting up on the clip.
      Ask FixBot
    2. IT-Riage Rev 3 Cylinder  Disassembly: step 2, image 1 of 2 IT-Riage Rev 3 Cylinder  Disassembly: step 2, image 2 of 2
      • Using a Philips screw driver remove the 6 screws holding on these 2 front panels. one removed they come off in 2 pieces be gentle with them as they are flimsy plastic.
      Ask FixBot
    3. IT-Riage Rev 3 Cylinder  Disassembly: step 3, image 1 of 1
      • Once the front panels are out of the way you should spot the Recline/ Zero Gravity Motor . NOT TO BE CONFUSED with the footrest motor . The footrest motor is the motor with a Wheel attachment on the end . Grease the recline cylinder by reclining the chair and once fully actuated apply grease as needed.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Be aware when re attaching front panels that the panels going on in the correct order. If done incorrectly they could be damaged upon operation of the chair.
Author
with
Nick
2,764 Reputation
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 80
All Time: 407
