IKEA Drill Battery Replacement
  1. IKEA Drill Battery Replacement, Battery: step 1, image 1 of 1
    • Use a 4 mm Phillips screwdriver to remove the seven screws to disassemble the housing of the drill.
  2. IKEA Drill Battery Replacement: step 2, image 1 of 1
    • Remove the sticker carefully from the bottom.
  3. IKEA Drill Battery Replacement: step 3, image 1 of 1
    • Open the housing of the drill.
    • While opening place the rotation switch apart.
    • Detach the electric circuit and place it next to the drill.
  4. IKEA Drill Battery Replacement: step 4, image 1 of 1
    • Cut each tubing from the three wires of the battery with a utility knife.
  5. IKEA Drill Battery Replacement: step 5, image 1 of 2 IKEA Drill Battery Replacement: step 5, image 2 of 2
    • Disconnect the three wires of the battery with a soldering iron.
  6. IKEA Drill Battery Replacement: step 6, image 1 of 1
    • Place each new tubing (three in total) on the battery wires through sliding them on each wire.
  7. IKEA Drill Battery Replacement: step 7, image 1 of 1
    • Attach the two batteries to each other with tape, in case you have two separate batteries.
    • Use solder and a solder iron to attach the new battery to the wires.
    • The black wire should be connected with the negative pole of the two-wire side.
    • The wire should be warm enough to solder the battery to the wire.
    • Slide the tubings on each connection and heat each tubing with a lighter to make them shrink.
  8. IKEA Drill Battery Replacement: step 8, image 1 of 1
    • Place the electric circuit and the rotation switch back into the housing.
  9. IKEA Drill Battery Replacement: step 9, image 1 of 1
    • Put the housing back on the drill through clicking and closing it.
    • Put the seven screws back into the housing with the Phillips screwdriver.
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 103
All Time: 11,952
