IBM Thinkpad T61 Hard Drive Replacement
  1. IBM Thinkpad T61 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Turn the computer over so that the back is facing upwards.
    • Locate the screw in the bottom left-hand corner of the computer.
  2. IBM Thinkpad T61 Hard Drive Replacement: step 2, image 1 of 1
    • Using a #0 Phillips screwdriver, remove the 17 mm screw.
  3. IBM Thinkpad T61 Hard Drive Replacement: step 3, image 1 of 1
    • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
  4. IBM Thinkpad T61 Hard Drive Replacement: step 4, image 1 of 2 IBM Thinkpad T61 Hard Drive Replacement: step 4, image 2 of 2
    • Locate the folded black tab within the hard drive port.
    • With a screwdriver, pull the black tab out of the slot.
  5. IBM Thinkpad T61 Hard Drive Replacement: step 5, image 1 of 2 IBM Thinkpad T61 Hard Drive Replacement: step 5, image 2 of 2
    • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  6. IBM Thinkpad T61 Hard Drive Replacement: step 6, image 1 of 1
    • Remove the plastic coverings on both sides of the hard drive.
    • Note that there is no hard drive in this picture but the process will remain the same.
Kyle
458 Reputation
4 Guides authored
Cal Poly, Team 8-58, Johann Spring 2013 Member of Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 65
All Time: 6,577
